Glider after doing some more research I have come to find out that with this plug and play you have to tap into the o2 sensors how is that done, it looks like you have to have a socket with a slice in the side to get it out, mine is a 08 RK. thanks again.
You can generally bypass the sensors with resisters that plug into the bikes harness once they are disconnected from the 02 sensors and they stay that way.
Then another unit utilizes the 02 sensors depending on which way you want to go here. Order it either way.
