I'd like to get your opinion on the Gen3 for my bike. Talked to Dobeck yesterday and they said I need the EJK part #9120333 which will not bypass the O2 sensors but will completely eliminate them. I'm to leave them screwed into the pipes, but disconnect the wires at the other end and not hook them back up to anything. Doesnt the computer need some sort of reading from the O2's??? I know you're the expert on the TFI or EJK, so I value your opinion. Thanks.
MY OPINION,,,,,NOT DOBECKS........Yes, the wires from the 02 sensors are disconnected..... (in my case capped-connected)
I have connectors that BY-Pass and FOOL the HD Brain that all is good...This allows the gen3 (TFI,Gen4) to
add the needed fuel and the HD Brain doesn't take it away, IT doesn't even know it is there...
IF you leave the 02 wires Hooked up, the HD Brain will try to get the fuel settiing back to the 14.7 level full time (EPA)
I don't know why Dobecks has not made caps for All the newer bikes..IF un-hooked they will do the same as MY Capped ones ... Un-capped they will trigger a code in the system BUT not change anything but show a code.....
Miffed at Tank? YES,,,, Tank knows why,,,, a comment I made a while back (answerd by Tank and posted like this one
for all to read) about One OIL in all three holes. Sating me WRONG and linking HD's opinion and AMSOILs opinion... SO my HD mechanic and I are WRONG? Plus a multitude of MEMBERS Here?
The Post? (can't be found) read like;
My stating "a Top HD mechanic I know saying"
"it was a BIG mistake by HD to do so,,,,"Gear oil is needed in a tranny"..... also saying "Just to SELL one oil for more$$$ and a lot Less shelf space needed to stock their HD product"...
"close from memory"
As I could NOT find that post I made OR Tanks Reply to it.... Where did it go??? MISSING?????????? OR I'd show it.
It must of gone AWOL :newsmile100:
I started this thread to KEEP the opinions of the Dealiers OUT... BUT..??.....
I didn't want the Companies opinions here..Just the users Beliefs.
Smitty901 had a good saying? "from my memory"
"Its your ride You decide"
Tank,,,,You asked me in a PM " Are you uspset with me?"
Yes I Was. BUT Not any more. Got it OFF My Chest...
I should of posted this in the Other Thread I Started?
