If the system won't produce any codes then what? The last time the code appeared while riding was July 17th, since then I have not completed 50 cycles. I tried to pull the codes last night but was unsuccessful. I jumped the #1 and #2 with a red connector, fit perfectly. I turned the switch, Fork Lock/Off/Ignition/Access, to Ignition. The red Key light illuminated then went off. Then, I thought I might have done it wrong, I turned everything off, kept the jumper in, turned the switch to ignition, turn the Stop/Run to Run. The Check Engine light came on, then went off, then came back on for 4-6 seconds then went off. After that nothing.
When I get ready to start for riding, the check engine light comes on as it normally would, then goes off for about 4 seconds then comes back on for 4-6 seconds then goes out. This indicates a stored historical code correct?
Thanks,
Jeff
Thanks,
Jeff
