J
Jack Klarich
Guest
In your picture, jump across the big battery lug to the small wire, this should spin the starter
And if it just whirls like when I hit the start switch, then it's the starter correct?
Hmm, OK. I will check it out... Let me check the battery first... Would the battery being too low really make is not engage?
I can pick up the stronger starter for only $139 right now... I should just do that if the battery is O.K... Just pop the new one on and call it a day![]()
Not a bad price, what kind of warranty?
voltage from the battery is 12.3 and at the starter 11.9. WHen I press the "start" button the voltage drops to under 1... does it just sound like the battery? What brand is the factory battery. This has some cheap looking "made in china" Power Source brand.
