Magister
@Catwoman
Yes, a new set of cable might not be a bad investment. I'm just a little shy of spending more money on repairs right now. Because ...
I truly feel for the guy with the clutch problem. The week before this whole not starting thing began I had to replace my ENTIRE clutch assembly. The bike started dragging with the clutch completely squeezed, and once moving running horribly as I shifted through the gears (high RPM no power to the wheel). I tried adjusting the clutch about a half dozen times before giving up and taking it in to the dealer. When they disassembled it they found the drum "wobbling" in the basket. It turns out a weld broke in there and the whole thing got fried. The burned oil, plates, etc. were impressive in their destruction. I brought all the parts home to use to get more familiar the clutch components.
Turns out Harley no longer stocks (or makes) the parts for the clutch in our bikes ... so I (well they) had to order the part from V-Twin Manufacturing. I got the last one they had in stock. The part itself was just over $700.00, then add in all the other little parts, and the 1.5 hours labor and there you have a $1000.00 repair bill. Now ... one week later ... this.
That's why I'm a little gun shy when it comes to buying more stuff I might not actually need.
@TQuentin1
I did check out the switch this morning. It seemed to be working correctly. I may not have tested right, but voltage was being passed, and the continuity was good. Also, the switches are actually pretty new. How new I don't know. The guy before me must have replaced them. In fact they (start and kill switch) are the newest looking plastic on any of the controls on the handlebars. Still black, with crisp white letters.
Like I mentioned to CatWoman above, I'm really hesitant to buy more parts than I need right now. If I get going down that rabbit hole, I'm afraid I'll end up buying the bike again in parts before I'm done.
@TQuentin1
