Phantomaoc
Yes, tried on several occasions to get it to show a code. The engine light has come on going down the highway a few times, but can't get it to show a code.
Scanner. Maybe.
1997 HD FLHTCUI with 29,000 actual miles. After riding over 50 miles, when I come to a stop, engine studders, misfiring, oil pressure drops, tried to check code on engine light with no results. If I ease the throttle up, and slowly take off it smooths out. Checked and made sure ignition switch was replaced during recall and it was. This has occurred 3 times so far, with outside temps in 80s. beginning to wonder with lowers, if it is getting hot?![]()
Have you checked the main circuit breaker? 29K miles is a bit early for it to start failing but those early CBs were known to lose capacity over time from heat; they are located right behind the rear cylinder which is a real heat generator. Symptoms are very similar to what you describe, shutting down but restarting and running OK again after a cool down.
Could be the connection, could be the breaker has just lost capacity from heat. IIRC, the breake is rated at 40A but if it has lost capacity it migh trip at 30A. Just a thought, seem you have checked or replaced almost everything else.:newsmile058:
