BUBBIE
Well-Known Member
IF the "O" ring around the pump housing came off or Out a little, pinched allowing in air,,,, it will not build up pressure.
This Does happen and the only way to really check is to PULL cam plate and Pump as an assembly,,,,,Leave the pump bolts(4) tight as they are not needed loose to pull ALL off together..
Then you can see IF the O ring is a problem... Is it pinched and sticking out around the housing..
Look at the face on the cam plate where the pump rides..? how deep is the run line .... just feel with your finger nail,,,, IF deep , this might be it...Normally a groove is there but Not deep.
Wished you were closer and I would come over to have a look..
report back,,,, Sorry for all the work to try to get it right..
This time when apart, and cams out, be sure to squirt some oil in the openings where the cams go in and the holes that go into the crank area(top area) and it will help lube the rods, before all goes back together.AGAIN.....
