J
Jack Klarich
Guest
I just did my 1000 mile service on my Fay Boy. What I did consisted of -
- Change oil - Mobile1 V-Twin - (2nd oil change)
- Change trans fluid Royal Purple (2nd trans fluid change)
- Change primary fluid adjust clutch
- Check drive belt tension
- Lube clutch and throttle cables and adjust
- Steering head should be checked follow manual depending on model. Some have grease fittings
- Change oil filter
- Check critical fasteners
Check any other items in your owners manual.
Be careful not to cross thread, overtighten anything a little extra time here will save you a lot of time and trouble. Do not overfill any fluid levels.
If you don't feel comfortable with something (e.g. springer front end) take it to the dealer and just have them do that part. You will still save money.
And it was fun Right?:s
