Admiral Nelson
Banned
If you search around you might could find one made closer to your area.
Also some folks make their own from flat strap. Actually the only part that is somewhat difficult is that the tank slides in between the OEM bolt hole brackets. So obviously you have an offset involved in the equation. And since the tank bracket is solid you have to offset from the outside.
The simpliest way around this is to use stainless washers at the tank mount with a longer stainless bolt (acorn head if you can find it).
Or if you have access to a friend with a welder, you can just weld an offset into your bracket (which how most lifts are made) and you are good to go. Sand and paint. Or if you use aluminum sand thru all the grits and then polish.
MTM (the one I bought) makes their lifts out of one solid billet piece of aluminum. A very sturdy mount, but I am thinking of cutting a section out of the bottom so as to route my cables under it instead of having to go over top of it.
Thanks for your help, but they are only sold in the USA and I am in the UK.
