dolt
Well-Known Member
Dolt I'd like to personally thank you for spending the time and writing such a detailed description. I've researched and looked at everything you've mentioned. One question I have is what type of pushrods would you suggest. I have stock now so probably wouldn't be a bad idea to upgrade to adjustable. Your thoughts? Oh and who supplies the tts100 cams
Only two places to buy, direct from TTS Power Systems and R/C Cycles; both located in CA. Steve Cole invented the SERT and had a contract with the MoCo for years until the MoCo had learned enough from Steve to come up with the SESPT and kicked Steve to the curb. Steve then developed the TTS Mastertune which, IMHO, is the current state of the art fuel management system although the DJ Power Vision is a very close second. Steve came up with the TTS100 cams and designed the profile to deliver a bolt in cam that would make torque from idle to 4500 rpms; the TTS100 does just that. The cams were introduced early last year and Steve had trouble keeping up with demand but I think he has caught up and the lead time is not what it once was. Steve has never released the cam specs so I don't know what they are.
Call Vickie at TTS (310-669-8101) or Ron at R/C Cycles (510-472-9755) to order cams. The SE Quick Install Tapered pushrod are fine for your application. PN 18404-08 includes pushrods, O-rings, tubes and clips.
You will need a tuner and dyno tune, so check your local area for a competent dyno tuner and find out what system he likes to use. There are a couple of well known tuners in Canada but I don't know if they are near you.
You can DIY the project, just need the service manual, basic tools and patience. The bearing puller for the inner cam bearings can be rented from Auto Zone or Advanced Auto in the lower 48, just need to be sure the correct size collet is in the kit before you leave the store. Don't recall you including mileage or model year but if still running OEM lifters, it might be time to change to a set of S&S standards.
