BUBBIE
Well-Known Member
***************************************I can't pick between the Two bikes for you But.... If you go 96" with a full Stage-One and a simple fueler like TFI or Gen3 from Dobecks,,, it will perform just fine..
That is what I did to make my 96" 09 FLHR respond like it should of off the show room floor....
Later I added the SE255 cams to give it the Better Boost.
"One Day" when i get Many more miles on the 96", I will go to the 103" with manual compression releases.
That is the plan...
I could just leave it where it is Right Now as it does Tickle Me Fancy....
If you go 103, what cams are in it, and does it come with compression reliefs?
(SE 255 cams and CRValves)
My ride will Have to Have Both the above in the 103" or Your 103" would be a No Go.
I could not agree more Trek.... But not needing to go 103"
I'm Not in any Hurry to tear into my 96" to go 103" either...
If the one?? above that Doesn't want to tear INTO the new engine,,,, the 96" like mine and Not a lot of work to change out the cams, just the side cover NOT the heads... WOW is WOW
