@ Shovels4ever I am just getting to work on it now.  Going to hit all connectors with contact cleaner allow to dry and put it all back together.  Then I guess the course of action to take is to Do the TRSSM relearn configuration, then make sure that Pin 5 from the ECM is poroducing 5VDC, other powered pins to and from the ECM to TSSM are what they should be.  then Voltage drop tests across all the sensors within said system CKP and VSS?  then finally  the actual U1016 tests. Hopefully it was some loose connection vibrating and receiving power then not instead of a dead Module as the TSSM's I have seen are upwards of $400 and at least that to double for a new ECM.
@Justjake I have to its my mode of transportation. The wife has her vehicle, but Im not going to deprive her of that if I can help it.
