Check your pressure with the bike in the air then check it on the ground, wow no difference. The internal air pressure does not change with added weight.
It depends how you are looking at it.
Does it make a difference that needs to be corrected by the user of the tire under normal use? No,, probably not.
Does it make an Absolute change in pressure whether the tire is loaded down with weight or not ? Absolutely. If it did not, then adding more and more weight would not cause you to exceed the load capacity of the tire.
By pressing down on the tire you are reducing the internal volume of the tire. the air must go somewhere. It gets compressed. When compressed the tire pressure goes up.
HMMM, the dynamics of physics, I like this:s
Good point. Some people will also argue this fact. If you were to remove the tire valve from a rim and let all the air come out of the tire, how many pounds of air pressure will remain in the tire.
An everyday person will say Zero.
A Physicist would say 14.7 lbs.
Who is correct?![]()
