I have 3 questions. Lets say we had an empty plastic liter bottle of Pepsi sitting on a table. The cap is removed but the bottle still has its normal "bottle of Pepsi" shape.
Question #1
1) would the air inside the bottle come out the open end on its own without the use of a vacuum pump if you squeezed the plastic bottle with your hand.? Yes or No
Question #2
2) When you squeeze the bottle with your hand and the cap is removed, are you REDUCING the internal volume of the bottle.? Yes or No
Question #3
3) Do you believe that if BEFORE you squeezed the bottle, if you had place a pressure gauge to the top of the bottle, would the needle pointer on the gauge go UP if you squeezed the bottle with your hand. Yes or No
If the answer to all those questions is YES, then you are blaming the wrong person for your frustration in thinking tire pressure does Not go UP when the applied pressure to the exterior of the tire goes UP. Don't shoot the messenger because I had nothing to do with it. Blame Sir Robert Boyle for his work with volumes & pressures back in the 17th century. Boyle's Law states,, Assuming that the temperature remains constant, the volume and pressure of a certain quantity of a gas are INVERSELY PROPORTIONAL.
What else can I say? I am not pulling this out of thin air.
