J
Jack Klarich
Guest
I tend to get a bit TOO techy at times sorry about the confusion, I do know both ways but cannot explain itBrother Jack, Brother Jack,
If you are indicating your pinion shaft and you are at .006 Total Indicator Reading you then divide by 2 to get .003 run out per side from the axis.
BUT nobody is asking for run out.
Bottom line is if they are asking for T.I.R dimension you don't divide it by two,
TIR is TIR.
The conversation was about measuring back lash in the gears. Keeping the pinion gear stationary, put a indicator on a tooth of the cam gear, rotate the cam gear and the reading on the indicator is the back lash. Again, no dividing.
Don't want to get into a spitting match here, but facts be facts :s
