dolt
Well-Known Member
I'm doing a bit at a time . I can afford the 37 cams and I can put them in . I'm going to wate till after the summer to get the 06 heads and jugs done . Can I put the 37 cams in my 03 without changing out the heads till I'm ready? will the springs be able to take the .510 without binding ? Thanks F.K.
Honestly, I have lost track of what the current configuration of your build is. Is it 88" or 95"? Did you install high compression pistons or not? Have the heads been worked or stock?
Generally speaking, you can install the 37 cams in either the 88" or 95" configuration; however, they will be soft on the bottom with stock heads in the 88" configuration but OK in the 95" configuration. No worries on the valve springs in either configuration.
Provide the current configuration of your motor will get you a more specific response.
