lorne
Senior Member
I did install the ground on he antena as the instructions indicated and this helped. But, I think the output should be a little better. Seems the other day when we were riding out the the country near no buildings, etc we could only reach about 2-300 years.
Even whenwe ride with the HOG group, the distance for all radios seems to be pretty short. May just be a wattage thing, I just don't know. Sounds like I need to get a meter and check things out.
if you bought your ant and it is a cb ant then it should already be tuned. check the connection to the radio. follow your coax if this has been on the bike for a while heat can get to the cable and melt it. run your hand along the cable, make sure the cable is still flexible. i have found burnt cable where it has melted an sections of cable that felt hard.
one more thing to check is to look at your connection to the ant. if it is hard wired check to make sure they are making good contact with out any corrosion.
the most problems with radios is the connections. and your cable is part of your connection
i would hate to see you go out and buy a meter for something you may only use once. if there is a professional (Motorola, Icom) radio shop in your area, ask one of the techs to check your swr. they would probably do it for free.
if your radio is burnt out get your ant and coax checked out before you install a new radio or you would blow out the new one as well
good luck and please let us know what you found
been messing with radio ant since i was 15 so always interested if there is a new problem to learn from
