SWR's are adjusted by lengthing or shortening of the antenna (in this case you can't) or the coax. Since the antenna length and design is predetermined by HD i would think the only way to adjust the swr (unless the radio has an internal adjustment) is to trim the coax. I always hated doing that. I don't think you'll ever get the distance that a car or truck will get. However, if the swr's are good, you could always add a linier for extra power boost and transmission range. Not legal, but certainly helps get you out there. Used to run one on my Pace 2300 in the mid 70's...with a pair of 102" steels. Man that thing would talk. Don't think the swr's do much for reception as that is a function of distance and the other transmitter.
