so you think the fuse is blowen for the ECM, the wire is hot because i tested it and have already replaced the broken pin with a new one, how ever i will double check the ECM fuse and let you know what i find, so i'll be back in 5
ok,went to check fuse and it was good,so i unhook the batt to clear the code, let it set for a few mins and then i hook the batt up and turn the key on and all my dash lights came on then they all went off and about 30 seconds later my check engine light came back on so i then check my codes again and i still have the code again(P0107) so my bike will make my check engine light come on with cranking and running it, but i did replace the map sensor the other day, so my problem is some where else ? ? ? thanks
