Your Map sensor was a combo (4 wire) sensor which included the outside air temperature,, Is that correct?
Take a close look at both male and female portions of position #25 of the ECM connector. That is the ECM input for the MAP sensor.
There is a un-used 3 wire connector that is down by the Jiffy stand. It has 3 wires going to it. Red/White,,,Green/Brown,, Solid Black. By any chance can you locate that un-used connector?
