dolt
Well-Known Member
Seems I have a few options now, thanks to everyone for the inputs.
So,
1. I can just leave what I've got and recheck in about 5-10K miles and go from there.
2. I can go the really cheap way and pull the pushrods from the top, replace inner bearings, and replace tensioners with the CYCO part. This method will buy me lots of time to consider a Gear Drive (and allow for Crank runout check)
3. I can go with the Chain conversion kit, replace bearings, pump, etc, -OR- I can go gear drives.
Since the first two options will either have time or buy me more time to save up, I'm leaning towards gears. Right now I'm looking towards the Andrews setup, but not sure which cam to use, the 21 or the 26. My riding style is 1-2 up 70-80MPH on interstate freeway, but mostly 2 lane roads with hills and curves and 50-60MPH.
The problem with Option #1 is that you are running the potential risk of a catastrophic failure; sudden and often with no warning. Granted, the possibility is remote but tensioners can look good one day and fail the next. I would not choose what is behind door #1 but your ride; you decide.
It would be hard, for me anyway, to go with Option #2 without upgrading the cams. You will have done all the work and a set of cams would not add that much more cost.
As for cam choice, the Andrews 21/26 have been the "go to" cams for otherwise stock 88" motors forever. However, there are new grinds that are available that will perform better. Your signature indicates that the bike you are working on could be a '03 or an '06 model. If an '03, you are limited to cams with .510"; if an '06, .600" is the max lift. So, if she is '03 bagger and you do a fair amount of two up riding; the 21 would probably be a better fit than the 26. If she is an '06; several other choices but the S&S 551 would really wake that 88"er up.
You will need a tuner with a cam install. You could probably get satisfactory results with the later Dobeck hardware but one of the more sophisticated systems like the TTS Mastertune and a dyno tune would be the way to go for max performance.
If you decide to go the SE Hybrid conversion route; orderin the kit from a discount online dealer will be cheaper than the Andrews kit which is made up of all OEM parts. JMHO.
