danthern
Other things known to cause chirping.
1. Blown head gasket
2. Throttle body blade
3. Oil pump gerotors
new throttle body too
I didn't remove the lifters but I'm skeptical that a lifter is the problem and here's why. The sound never changed a bit after all the things I've done, including a lifter swap (just happens to be the Comp Cams VThunders that you mentioned). I think if it were a lifter there would be some change in the quality of the sound. The thing that may be helpful to you is that when I'm riding it's pronounced on acceleration. When I decelerate I don't hear it. I recently changed the oil and didn't notice an excessive amount of metal on the plug. Oil pump and head gaskets have been replaced.
In a previous post you indicated that the noise presented at idle and you have described it as a "chirp" which gave cause for me to eliminate detonation as a source of the noise. However, your above statement that the noise presented on acceleration but not on deceleration is symptomatic of detonation. I don't know the particulars of your motor configuration, i.e., bore, head gasket thickness, pistons and tuner/state of tune. But I do know that the 255 cams have very early intake close which can, in certain configurations and lack of a proper tune, can cause detonation. I would be interested to know what your CCP is. Have you run a compression test? What tuner do you have and has the motor been tuned?
If the noise does present at idle, listen at idle with trans in neutral and clutch engaged and disengaged to see if the noise changes.
With everything you have done and checked, I am starting to run out of ideas but do think you should run a compression check.
OK, I listened to the video and, wait for it, sounds very much like a valve train lash on one rocker arm. I know it is hard to diagnose noises via a recording but I am betting the noise is in the valve train; you just need to track it down.
Collapse the pushrod covers, pull the plugs, put the trans in 6th and put each piston at TDC on the compression stroke; I am betting you will find some vertical movement in one of the pushrods. If not, replace the lifters, one has collapsed; upgrade to a set of S&S standard lifters. If neither of those eliminates the noise, you will have to go up top and remove the rocker box cover and let the motor idle with the cover off and see where the noise is coming from; I am betting you won't have to do that.
I know, you replaced lifters and don't believe it is a lifter or valve train related but that's where my money is. Check it out.:s
Thank you....I'm actually planning to order those very lifters, and a S&S Quickee Push Rod kit. I currently am running the Crane Cam adjustables. Take about a week to get that stuff in. I'll keep you posted...Thanks again!
