gusotto
Junior Member
Last year, I had my compensator ('07 Ultra) replaced w/new SE Compensator (old style, $250) and it came with a new rotor..
None of the new compensators will work with your old rotor/flywheel (with the alternator magnets in it). The old kit for the SE compensator came with a new rotor. I haven't seen the parts list for the most recent version to say whether the rotor is included or purchased separately. Regardless, you will need a new rotor with the new compensator.
The new 2014 P&A book shows the new SE Compensator that is standard on the 2014 bikes.
It also shows no rotor in the kit because the new rotor is already on the new bikes.
I asked the parts guy about the needed rotor. Turns out that it's the same rotor that came with the earlier kit. (I think it is about $117, all by itself.)
Better oiling with the latest SE Compensator ($300) but you'll need the rotor that was in the older SE Compensator kit.
Looking at over $400 for everything needed, plus gaskets, lube and labor.
If it starts to get noisy, get it fixed as it will take out the starter gears. That gets expensive.
My starter gears were fine. You can see them when the primary cover is off.
Mine only made the noise twice, right at the end of the riding season. Did checking on the internet and found what was the probable cause.
I took advantage of free storage if I had either service done or parts bought while in winter storage.
