I did replace the “o” ring in the mixture screw. I will have to ride some more because I didn’t take note of when it coughed. I thought about taking a drill bit and measure the hole in the slide but didn’t. The taper on the tuner needle is a lot different then the stock from the 93. The needle jet would match the needle in tuner same with stock? I can take the needle, needle jet and emulsion tube and slide/ spring out of the stock carb and get a bigger main jet.
