An oscillation that builds on input energy rather than being damped by losses is what causes the wobble. The losses are related to contact patch friction loss, steering preload (bearing friction losses i.e. fallaway setting), cable/wiring dress between bars and frame, the riders' arms and grip (affecting transfer)...and that is just part of front end steering "dampening".
As you probably know, all mechanical things like bikes have a "natural vibration frequency" like bridges and such...continually putting energy into that frequency will make it oscillate unless friction or dampening losses are imposed...to "detune" this, otherwise bad results will occur.
Short answer: if you have a wobble...do the fundementals to find root cause 1.) what was the last accessory or service done to the bike? 2.) did a check conditions that may have induced the wobble...lsolo/2-Up/loading, speed, accel or decel ? 3.) check tire/wheel pressure/condition, fallaway/lock to lock movement, lubrication and remove unnecessary load high up?
If still there SIMPLIFY conditions to the basic factory equipped bike. Steering dampers, Tru Trak and such are add-ons used to "detune" the oscillation but do not REMOVE the cause...so are a "Quick" (read expensive) way to mask the symptom. HD would not intentionally sell a bike with a "death wobble"...and they have invested millions in R&D to prevent such...Product Liability is scary to ANY manufacturer.
