free website stats program Dyna Footboards/Heel-Toe Shifter | Page 2 | Harley Davidson Forums
I have the FXDP kit you mentioned to my 2007 Street Bob. I love the boards and heel/toe shifter and would never go back to pegs. As Hobbit mentioned, individual parts from HD are available but are costly. I only needed to modify the shifter mount bracket.Everything else boltted right up.
Hi Ice62, I own a 2008 Dyna Superglide (FXD) and want to adopt you solution. Could you give me more directions on exactly what you bought to install your footboards.
My bike has forward controls, but I kept the mid footpegs, so I have the two fixation brackets for the boards. Thanks.
Here are the full floorboards I put on my Wide Glide. Love them to death. They will scrape if I corner to hard but otherwise comfy as can be.
Lets try it this way.... Can anyone supply a parts list for the Dyna Floor Board Kit 50601-01? As of 09/10/08 I've searched and Googled for it but find no exact parts list. Anyone?
Harley Part number for the list is J01921 - it can be found on web in PDF format. but here it is. Parts are about 700.00 - well worth it if that is what you want. Fit all thru 2005 with no modifications. 2006 and newer require a bracket to be made for the shifter - other than that bolts right up.
File is too large to upload - but I can email to anyone wanting this.
Item Description Part No.
1 Bolt, 5/16-18 x 5/8 hex HD 2882W
2 Hex cap screw, 5/16-18 x 2.00 (2) 3023
3 Socket head cap screw, self tapping (8) 3214
4 Set screw, shaft cover 3231B
5 Assembly, rear brake pedal 33699-01A
6 Assembly,shift lever 33704-01
7 Assembly,adjustable shifter rod 33719-79B
8 Lever, shifter, machining, polish 33706-01
9 Assembly, shifter plate, polish 33700-01
10 Cover, shifter lever, rubber (2) 33619-85
11 Retainer,shift lever
for 1996 to 2000 models 34639-93
11A Retainer bracket, shift lever,
for 2001 and later models 34639-01
12 Cover, shifter shaft 34640-93
13 Washer, wave, overlap type (2) 34641-01
14 Linkage, rear brake push rod 41954-01
15 Pad, brake pedal 42416-83
16 Clevis pin 42460-80B
17 Socket head cap screw 4740A
18 Assembly, right front footboard 50521-01
19 Right rear footboard support 50526-01
20 Left front footboard support 50529-01
21 Left rear footboard support 50530-01
22 Assembly, footboard (2) 50632-85
23 Shoulder bolt, 1/4-20 x 1 (4) 50635-82A
24 Cotter pin 515
25 Washer, 5/16" (2) 6016
26 Washer, 1/4" 6099
27 Washer, 7/16" 6516HW
28 Washer. 5/16" 6702
29 Lockwasher, 3/8" (8) 7045
30 Nut, hex, locking, 5/16-18 7710W
31 Flange nut, 1/4-20 (4) 7716
32 Acorn nut, 5/16-24 7736
33 Hex jam nut, 5/16-24 7744
34 Lock nut, nylon insert, 7/16-14 7827W
24 Cotter pin 515
Please, send to me too: murad@mp.rs.gov.br.
Could you please send the file to me also.Thanks. The local HD shop is saying all the parts are obsolete. Has anyone had a problem ordering the parts individually?
The kit as a whole is obsolete. All the individual parts should be available. I purchased a few replacement parts for the original kit a few weeks ago.
There is a place called Walters Workshop that has shifters that are 2" over standard length. with size 12 feet I needed a bit of extra room between the heel toe shifter that comes standard from the motor company. one thing about using the longer shifters, you put more torque on the shift lingage so you may want to go to an aftermarket piece with the universal type joint as opposed to the standard barrel connector.
