Hi,
New guy here... I was just wondering the same as some of the previous posters if these parts are still in fact available through HD. I talked to my regular local parts guy and he said that all of the part numbers I was showing him from the list posted here were obsolete.
A few months ago I stumbled into a deal to acquire most the the parts in the kit but are still missing the shifter shaft assembly, shifter rod, and brake rod. Im not worried about the hardware as I can obviously get that anywhere.
Any help would be appreciated.
Thanks!
This is how I did the foot boards on mine. I had to get a softail footboard for the left side and make a bracket. The Dyna footboard are 10 inch on center for the mounts and the Doftail is 8 inch on center. Had to do this to make room for the EGlide shifter to bolt on. Did this mod over the winter and it works great and have had no problems or issues with it. The one thing I really like about this method is you have the full use on the footboard.
Here is a complete list of all the parts you would need to do the footboards:
FROM THE J01921 parts list
Item Description Part No.
3 Socket head cap screw, self tapping (8) 3214 - 1.50@
20 Left front footboard support 50529-01 - 50.76
21 Left rear footboard support 50530-01 - 50.76
22 Assembly, footboard (1) 50621-79A - 41.87
23 Shoulder bolt, 1/4-20 x 1 (4) 50635-82A - 1.65@
29 Lockwasher, 3/8" (8) 7045 - .29@
31 Flange nut, 1/4-20 (4) 7716 - 1.10@
7 Assembly,adjustable shifter rod 33719-79B - 16.07
18 Assembly, right front footboard
and brake pedal bracket 50521-01 - 50.76
19 Right rear footboard support 50526-01 - 50.76
22 Assembly, footboard (1) 50632-85 - 46.86
FROM THE DYNA DEFENDER PARTS LIST (POSTED EARLIER IN THIS THREAD)
1 Pin, Cotter 515 - .40
3 Screw, 3/8-16 X 1 Torx 4059 - 1.93
4 Washer 6099 - 1.10
6 Washer 6516HW - 1.00
7 Washer, 3/8 X 13/16 X 1/16 6701 - .08
9 Nut 7744 - .55
10 Nut 7827W - 1.12
14 SHAFT, pivot 33689-02 - 28.93
16 Pedal, Brake 33711-02 - 42.67
17 WASHER, spring wave 34641-01 - 3.52
26 Push Rod 41954-01 - 19.02
29 Pad, Pedal 42416-83 - 3.74
31 Pin, Clevis 42460-80B - 2.00
Total of Harley parts (looked up and priced per Zanottis web site) - 439.21
Shifter kit from EGLIDEGOODIES.COM - 199.99
TOTAL OF ALL PARTS NEEDED - 639.20
Metal plate per earlier posting to move left rear foot board bracket forward. 5.00 maximum
Follow the instructions in J01921 - Torque of the bracket bolts (3214)is 37 foot lbs - Torque of the shoulder bolts (50635-82A) is 12 - 15 foot lbs - all other 17 - 20 foot lbs
