after my third unsuccessful adjustment, I run my screw all the way out to prove to myself their is a problem(threads came out too). The factory cross threaded it and I was never moving it enough or at all, but it would lock tight. It only slipped at high speed/high gears 2 up. I put in new adjuster plate and it slipped worse, the damage was done. (could have been heavy oil, syn oil, weak spring,clutch plates looked ok)After 7000 miles, SE heavy spring and Barnett Kevlar x plate set I have a grabbing clutch. I was going to need stronger clutch anyway. FYI, using B&M original trick shift fluid.
thanks for tips, I was pretty sure I could follow directions !!!
