It's not good for the valves either.
That thought crossed my mind but I figured I'd be safe with 3 gal. of premium still in the tank and 2 gal. of 109 mixing in with it...
Heat and vibration play a part in the equation but the cause (if this is what it is) was because the harness was strapped too tightly in a rubber mounted engine that moves.
There is no advantage of using the 109 other than if you have too much cash in your pocket and want to eliminate it. That's a LOT of 109 to put into the tank, I wouldn't use it at all, just go for the next higher octane pump gas if you are having pinging problems.
If you have a pin hole and loosing fuel pressure from it, a full tank isn't going to make much of a difference.
The usual problem with this injector wire is right near the plug itself and the copper is separated inside the insulation making it hard to diagnose. As the heat of the engine transfers on warmup, things can change position and cause an intermittent miss. Have you eliminated the ignition as a source of the miss yet?
Is the wire repairable or do I need to get a new front injector?
You should be able to get a new pig tail, this being a delphi set up it is = to GM plugs Try Napa![]()
Ahhh, the parts guy told me that the bike harness was a single unit after I asked him if I could just get a connector. He said he spliced his....
