free website stats program Engine skip or "Bucks" | Page 3 | Harley Davidson Forums
So what do the hoses plug onto in the backing plate?
Cheers,
On mine I used the banjo breather bolts that came stock, I drilled them a little bit bigger for more flow.
If you look at the post from dolt (post #14) his shows to use 2 brass fittings but I chose to use what I had.
If that was you TQ who cleaned up my pix thank's, told you i'm not good with a camera and a down load.
Your right. That will be easy. I will definetly do this.what size I D hose is that? Looks like 3/8 ot 1/4.
I don't recall I did it awhile ago. If you use the stock banjo bolts take one with you to the parts store and get the size that fits snugly over the head of the bolt. If you go the way described in post #14 get the size that fits snugly onto the fitting.
Either way you'll accomplish what you set out to do.
I too am a old evo rider,I still have one. In 2014 when I bought my 012 road king the salesman said to me, welcome to the 21st century.
Yeah. I couldn't count how many times I would be at a dealership wanting something for my Evo. The parts guy and / or service guys would have that deer in the headlights look on their face. LOL
Well here's a short update for what it's worth. Haven't really had time to do anything and won't until this weekend. But yesterday I rode it about 40 miles and it ran fine. No skip / jump / buck or whatever you want to all it. Same gas, same everything. Then this morning I rode it to work. Only about 6 1/2 miles but it coughed, spit back through the intake, jumped, puked and bucked all the way to work BUT ONLY when running at 1700 - 2000 RPM's. No matter what speed (mph speed), no matter which gear. Anything above or below 1700 - 2000 RPM's and she ran fine. ?????
Could be fuel or it could be a electrical issue. Try the wiggle test on the injector wires, they have been known to break or crack leaving you with a bad connection.
Recheck for codes, the procedure for your model and year should be in the self help section.
Here's the procedure for bench testing your coil.
If you want to "bench" test a coil, remove wires, attach a hot 12 volt to the battery (batt, +, etc.) terminal. Then attach a wire to the ignition (ign) terminal and touch ground and remove. Should throw a spark from the high tension lead with each application of 12v and removal. The ground wire basically imitates the function of the ignition points/module. If the high tension lead terminal is gapped a reasonable amount from the engine, there should be a bright white spark. Weak or orange spark indicates (low voltage...or) bad coil output.
Here's how to run the diagnostic code test and what the codes mean for your scoot.
  1. waterdog, Jun 21, 2007Report
    #5Like+ QuoteReply
  2. gliderVeteran Member
    44
    That was for the 00-03 bikes, this is for the 04 to present ones with the serial bus setup
    The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
    Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
    1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
    2- Push odometer reset button in & hold.
    3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
    4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
    5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
    P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
    S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
    SP = speedometer
    T = tachometer
    6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
    7 - Record the codes.
    8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
    NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
    9 – Press and release the odometer reset button to continue to the next module.
    10 – Turn Ignition switch to OFF.
    DTC FAULT CONDITION MODULE
    B0563 Battery Voltage High TSM/TSSM
    B1004 Fuel Level Sending Unit Low Instruments
    B1005 Fuel Level Sending Unit High/Open Instruments
    B1006 Accessory Line Overvoltage Instruments
    B1007 Ignition Line Overvoltage Instruments
    B1008 Reset Switch Closed Instruments
    B1131 Alarm Output Low TSM/TSSM
    B1132 Alarm Output High TSM/TSSM
    B1134 Starter Output High TSM/TSSM
    B1135 Accelerometer Fault TSM/TSSM
    B1151 Sidecar BAS Low TSM/TSSM
    B1152 Sidecar BAS High TSM/TSSM
    B1153 Sidecar BAS Out of Range TSM/TSSM
    P0106 MAP Sensor Rate of Range Error Carb
    P0107 Map Sensor Failed Open/Low Carb
    P0107 Map Sensor Open/Low EFI
    P0108 Map Sensor Failed High Carb
    P0108 Map Sensor High EFI
    P0112 IAT Sensor Voltage Low EFI
    P0113 IAT Sensor Voltage Open/High EFI
    P0117 ET Sensor Voltage Low EFI
    P0118 ET Sensor Voltage Open/High EFI
    P0122 TP Sensor Open/Low EFI
    P0123 TP Sensor High EFI
    P0261 Front Injector Open/Low EFI
    P0262 Front Injector High EFI
    P0263 Rear Injector Open/Low EFI
    P0264 Rear Injector High EFI
    P0373 CKP Sensor Intermittent Carb
    P0373 CKP Sensor Intermittent EFI
    P0374 CKP Sensor Not Detected Carb
    P0374 CKP Sensor Synch Error EFI
    P0501 VSS Low Carb
    P0501 VSS Low EFI
    P0502 VSS High/Open Carb
    P0502 VSS High/Open EFI
    P0505 Loss of Idle Sped Control EFI
    P0562 Battery Voltage Low Carb
    P0562 Battery Voltage Low EFI
    P0563 Battery Voltage High Carb
    P0563 Battery Voltage High EFI
    P0602 Calibration Memory Error Carb
    P0603 EEPROM Failure Carb
    P0603 ECM EEPROM Error EFI
    P0604 RAM Failure Carb
    P0605 Program Memory Error Carb
    P0605 ECM Flash Error EFI
    P0607 Converter Error Carb
    P1001 System Relay Coil Open/Low EFI
    P1002 System relay Coil High/Shorted EFI
    P1003 System relay Contacts Open EFI
    P1004 System Relay Contacts Closed EFI
    P1009 Incorrect Password Carb
    P1009 Incorrect Password EFI
    P1010 Missing Password Carb
    P1010 Missing Password EFI
    P1351 Front Ignition Open/Low Carb
    P1351 Front Ignition Open/Low EFI
    P1352 Front Ignition Coil High/Shorted Carb
    P1352 Front Ignition Coil High/Shorted EFI
    P1353 Front Cylinder No Combustion EFI
    P1354 Rear Ignition Coil Open/Low Carb
    P1354 Rear Ignition Coil Open/Low EFI
    P1355 Rear Ignition Coil High/Shorted Carb
    P1355 Rear Ignition Coil High/Shorted EFI
    P1356 Rear Cylinder No Combustion EFI
    P1357 Intermittent Secondary Front EFI
    P1358 Intermittent Secondary Rear EFI
    U1016 Loss of ICM/ECM Serial Data Instruments
    U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Powertrain Security Status TSM/TSSM
    U1064 Loss of TSM/TSSM Serial Data Carb
    U1064 Loss of TSM/TSSM Serial Data EFI
    U1064 Loss of TSM/TSSM Serial Data Instruments
    U1097 Loss of Speedometer Serial data Carb
    U1097 Loss of Speedometer Serial data EFI
    U1097 Loss of Speedometer Serial data TSM/TSSM
    U1255 Missing Message at Speedometer EFI
    U1255 Serial Data Error/Missing Message EFI
    U1255 Serial Data Error/Missing Message Instruments
    U1255 Serial Data Error/Missing Message TSM/TSSM
    U1300 Serial Data Low Carb
    U1300 Serial Data Low EFI
    U1300 Serial Data Low Instruments
    U1300 Serial Data Low TSM/TSSM
    U1301 Serial Data Open/High Carb
    U1301 Serial Data Open/High EFI
    U1301 Serial Data Open/High Instruments
    U1301 Serial Data Open/High TSM/TSSM
    2006 models with 02 sensors (Dynas)
    P0131 Front 02 sensor lean for any length of time
    P0151 Rear 02 sensor lean for any length of time
    Above codes can also be set if 02 sensor fails.
    AFR – Air Fuel Ratio
    ATS – Air Temperature Sensor
    BAS – Bank Angle Sensor
    CCM – Cruise Control Module
    CKP – Crank Position Sensor. The CKP generates an “AC signal” which is sent to the ECM where it is used to reference engine position (TDC) and speed. Home position established by taking readings off the 22 teeth on the alternator rotor.
    DTC – Diagnostic Trouble Codes
    ECM – Electronic Control Module. (The Computer) Computes the spark advance for proper ignition timing and fuel control based on sensor inputs (from CKP, MAP & TP sensors) and controls the low-voltage circuits for the ignition coils and injectors. The dwell time for the ignition coil is also calculated in the microprocessor and is dependent upon battery voltage. The programmed dwell feature gives adequate spark at all speeds.
    ECT – Engine Coolant Temperature. Sensor also controls the cooling fan relay that provides 12 Vdc to the fans.
    EFI – Electronic Fuel Injection
    EFP – Electronic Fuel Pump
    ET – Engine Temperature sensor
    FI – Fuel Injectors
    FPR – Fuel Pressure regulator
    IAC – Idle Air Control actuator
    IAT – Intake Air Temperature sensor
    ISS – Ion Sensing System…detonation detection
    MAP – manifold Absolute Pressure sensor. The MAP sensor monitors the intake manifold pressure (vacuum) and sends the information to the ECM. The EMC then adjusts the spark and fuel-timing advance curves for optimum performance.
    TP – Throttle Position Sensor
    VE – Volume Efficiency
    VSS – Vehicle Speed Sensor. Used as an input for idle speed control
    #5Like+ QuoteReply
    44
    SP = speedometer
    T = tachometer
    P0501 VSS Low Carb
    P0501 VSS Low EFI
    FI – Fuel Injectors
Great info. Gonna print this out to use and keep on hand. Thanks
