NCBILL
Lobo1, first off, I would suggest copy / paste to your documents the above list that Jeff supplied, can come in handy. Keep a copy in your saddlebag, in a zip-lock freezer bag for protection, and quick access to whenever you're out on the bike. Next.......I'm just tossing up another suggestion, if your "new to you" Twin Cam is a 2006 or older. Has the bike been serviced, ever, in relation to changing out the original style cam tensioners? If not, or if you don't know for sure, next oil change drain the spent oil through some white cheesecloth, and look for yellowish or orange particles, that will be an indication the cam tensioners are failing. Unfortunately, all the ones I've run across are the inner tensioner, which is really hard to see. IF that is, in fact, what's happening, I can imagine the oil galley is beginning to clog, hence, the reason for bucking at lower rpm's. At higher rpm's, the oil is just barely being forced past the trash from the failing tensioner particles. I may be stretching my theory a bit, but realistically I can see that happening.
