I didn't mess with any of the adjustments when I rebuilt the carb. It will run if I throttle up then push in the enricher but it runs really rough and backfires.
Still say the low speed circuit is blocked somehow or an intake leak but I think you checked for that.
Is thew cap still covering the idle mixture screw?
If so remove it and try adjusting the idle mixture when fully warmed up.Should be about 2 1/2 turns open from LIGHTLY seated and adjust from there as needed for the highest and steadiest idle speed, then close just a hair (1/16 turn)
