free website stats program Engine won't run unless enricher is pulled out | Page 3 | Harley Davidson Forums
i have the same problem-engine dies at idle,no vacuum leaks,was told voes could cause it ??????????
Posted previously
The idle orifice and the idle needle are plugged with carbon from popping back.
Try blasting Gum-out through the idle air intake orifice, other wise remove the idle screw plug and remove the needle, clean it and the orifice.
Note the turns, sequence the spring, small washer and o ring come out when removing the idle fuel adjuster needle so it goes back the same
Al
