Scrounger
I went with a different approach than most. I went with a 2 into 1. I originally ordered the V&H Propipe Chrome, but it was back ordered 3 different times, so I changed it to the V&H Propipe High Output with is a black exhaust with a chrome end cap. It has a 4" outlet and at normal driving speeds it sounds nice, just a rumble that doesn't overpower the music. Crank on it and it sounds fantastic. It actually comes with 2 sets of O2 bungs and plugs for them. I went with the SE 255 Cams, V&H VO2 air cleaner and PC V. I ordered the auto tune for the PC V and it is supposed to be in tomorrow. I think it looks really nice and the ProPipe HO is less than $700 which is much cheaper than most full systems that gets rid of the cats. The 2 into 1 is not a cheap way to go, but neither are new head pipes and slip-ons or a tru dual system. Lots of good choices out there, just make sure you specify it is a 2010 as the 2009 systems are different (different O2 sensors/location).
Sgt
If you are using the PCV it has the larger wide band O2 sensors and you will need the 09 pipe not the 2010 which uses the narrow band O2 sensors. I have the power duals on my Limited and the sensors are moved up to by the heads since the PCV has its own sensors and the OEM sensors are removed.
