free website stats program Flat Tire at Speed - Best Way To Stop Bike | Page 3 | Harley Davidson Forums
Have to ask. What brand tire. Firestone 500?
It's a Metzler. I have to believe that he must have hit/run over something to cause that kind of problem. We had been on the road, headed to the Blue Ridge Parkway, for about 2 hours when it happened.
Triplej:
Nope, we had been cruising the slab and he wasn't on the brakes.
Believe it or not, he was just noticing that the bike was feeling 'squirrely' when I smelled hot rubber and started getting the bits of rubber bouncing off my windshield and helmet. I pulled up next to him and started frantically pointing for him to pull over. If he had ridden another 1/4 mile, the outcome would have been terribly different.
It like a re-cap tire that separated. When something like that happens, Metzler should be concerned enough to investigate the reason. But I bet if they were contacted, it would get sweep under the rug.
I am sure this sort of occurrence with the metzler tyre has been reported previously on the forum and it was suggested that perhaps not running the correct pressure for these tyres may have been part of the cause as Metzler recommend a fairly high pressure for their tyres
mine were both metzler me880. the high speed had a hole in it bout 3/4 in like i hit a piece if steel in the road. it was in a construction area and i was riding sweep close to the center of the lane. didn't come apart but did smell like burning rubber when i got stopped.
My scare at speed happened in 1986 while I was riding my 1980 Superglide on the loop in San Antonio, in the rain, at night, and with fairly heavy traffic and with my riding partner next to me.
We were about half-way into a long curve when, all of a sudden, this high pitched whinning sound started coming from under the bike. It screamed for about 5 seconds. Then pow!!! and the rear wheel locked up. Of course, at that moment and since we were running about 55mph, my partner shot on ahead of me. I didn't apply any brakes. I just let the back end do what it wanted to do and I just compensated with the front end. My partner went to the next exit and got on the feeder to come back to see what was wrong.
Well, what was wrong was that here I am, dead stopped in the middle lane of the freeway, in the rain, at night, and traffic blasting by me at 55 mph!!! I was freaking out, to say the least. One thing that I had in my favor was that since we were on a curve I could see down the freeway to be able to tell what lanes the on-coming cars an trucks were in. Cars and trucks were blasting by me on both sides, soaking me. There was nothing that I could do but stand there with my finger on the turn signal. During one lull in the traffic, I tried to drag the bike off of the freeway but made it only one lane. My partner, by then, had made it back around to help get it the rest of the way. We called a friend and he came and loaded up the bike and took it to a shop where they found out that the bearing that goes between the clutch and the tranny had exploded. Not only did pieces lock up the rear wheel, they blew a hole in the bottom of the primary case.
Moral? Do not hit your brakes. Just ride it out of you can.:newsmile071:
I had another scare with the front tire. Same bike. In 1987. I was at work at a plant down in La Grange, Texas. I received an emergency message from the guard shack (see my post in the 'In Memory section'). I hopped on my scoot and had the needle pegged the entire 34 miles to the house in the country. When I arrived at the house, I noticed a knocking noise. I didn't worry about it until after my emergency had been takin care of. For about a week or two I would take the bike out on I-10 to try and find out where that knocking was coming from. Everyone told me that it was in the primary. After a while I gave up. Then one day I was going to take some photos of a 'hottie' on my bike and I noticed that there were three chunks of rubber, each the size of the bottom of a coffee cup, missing, down to the cord, on the front wheel. The noise that I was hearing was the rubber hitting the fender. Moral? If you hear loud noises, check your tires first. I do.:newsmile071:
Holy cow. I read every one of these posts carefully. Took me awhile but I've had a flat tire once under very lucky circumstance and have always wondered how I would have handled it in a worse situation.
These posts have educated me well. I know one thing after reading these it further convinces me a good thing that I always if possible ride the outside lane. I like being next to grass on one side. In PGR escorts on interstates we are forced to ride in the middle of 3 lanes and I have to deal with semi's just a couple of feet to my right.
But when I have a choice I love the right most lane. Thanks guys for these posts.
Wow!! Sitting idle in the middle of a highway on a curve on a rainy night!! You are truly one lucky person!! Seriously. I'd be thinking about when, not if, am I going to get rear ended! Thank God that turned out okay for you!!
Actually, I was standing and facing the traffic while holding the bike. I had decided that if I saw a truck or car coming around the curve in my lane that I was gonna run off of the freeway. If the traffic would have allowed me to do so, that is. I would have had no other choice.
Good thread. Appreciate everyone sharing their experience and glad you're still around to tell it.
Thanks for the stories. I've learned a lot that will help if I ever get a flat at speed. Anyone ever have a front tire go down and how did you handle it?
PS. I'm glad these stories all ended well.
