Hoople
Account Removed
Also clutch hub could take a lot of abuse as well as chain and main shaft![]()
Jack, Great point & that is true.
Something the OP may be able to supply.....
The frequency of a vibration that was clutch hub related would be at a much lower frequency than a vibration that was at crank RPM. While riding the bike, when the vibration was at or near peak resonance, you may be able to look at the tach and make a mental synchronization of engine speed to the vibration that was being felt at the time. If they happen to feel "in sync" with each other, you would know it was engine related. The ratio from crank to clutch basket is so dramatic (at least 2 to 1) it should be possible to distinguish between the two while riding the bike.
I have never had this exact problem but I bet you would be able to distinguish between the two just from the difference of vibration since the ratio between crank to basket is so large.
