If you can find eventually find that pic I would appreciate it.
If the groves are in the correct rotation direction, it seems like it should work while rotating.
I think the straight lined grooves would work better when the sitting still to allow oil to drip down inside, but may actually allow oil to be flung out, centrifugally, when spinning.
Thanks again, the photos really help me understand the issue!
IMO, the stock compensator on a heavy touring bike, as used from 2007-2010, is garbage. There was a definate need for something stronger.....thus the SE Compensator. I put mine in and consider it to be the best mod I have done.
It cured the hard banging on startup and a lot of the other problem chattering and lurching that was being experienced on the heavier bikes.
With that said, Lets address the "fretting - galling - lack of lube" issue....
Sorry guys but I'm just not buying into it. I think folks are making a lot more out of this than what it warrents.
I put the SE compensator on my 07 when it first came out and after 43,000 miles I have had zero problems.
And NO....I am not pulling the primary back apart to look.
I see the type of "fretting" you are talking about......I've seen that same type in many mechanical applications, more times than I can count....the one I can think of right off the top of my head is in the planetary gears of a Cat powershift transmission.
Point is....I have never seen a failure that could be directly attributed to this ...That's never!...as in 30plus years of looking at this stuff from the working end of things.
Y'all do as you wish but as for me....I'll run it as I have been since I put the SE Compensator in.
Yesterday when I went to start my scoot, it took 3 attempt for some reason and there was a loud "clack" that sounded like it was comming from the compensator. I have 43K on the clock and I have never had anything done to it (stock compensator).
Thanks for any help.
Porter,,, If it continues as a starting problem Could it be the battery???
I see your bike is an 07 and if the Original battery???
If your problem of 3 attempts was Low Cranking power, Just maybe the Bat. and nothing to do with the stock comp.
Dont forget about the starter/ ring gear problems with the 07 models just sayin
I know the battery won't last forever, but I keep it on a tender whenever I am not riding. This is the first time this has ever happened and I have had no issue the rest of this week while commuting. I will put a meter on the battery and check it though to check the simple stuff first.
I didn't know about this issues (and still don't) but I will look in the help section and do a search.
Thanks Jack and Bubbie!
