Gotta love an easy fix. I hope it keeps working for you.
It is not a big job to do a master cylinder rebuild just ensure you take good care on draining the system as if there is any glycol based fluid still in there and it gets on the paint it will bubble and strip the paint off
It can take a wee nudge to get the old parts out of the master cylinder but as they are heading for the bin anyway
With the master cylinder on the bench I use a suitable sized allen key in where the banjo bolt fits push on to the piston inside and tap the end with a mallet and it all pops out take note of the order and orientation of the old parts as they come out clean everything and fit the new parts
some cylinders use a cir clip, yours presses in![]()
....is there a recommended lubricant for the piston when re assembling?Thanks Jack...I need to invest in a Manual of some description, only had her a couple of months!......Saturdays project all set....
