free website stats program Front brake lever, excessive play | Page 5 | Harley Davidson Forums
Thanks for the tip, all seems well so far!....but will look out for it.
After doing the rebuild TWICE, then again to install my little spacer I did notice that the "lube" that comes with the HD kit seems to cause some drag on the piston O ring and primary cup. I installed the spacer that I made and didn't use the lube. No more issues for about the last year?? or so.
The spacer adds about .125 inch to the spring length. Enough to give a little more return on the lever but not so much that it pushes out the piston cap and wiper before you can re assemble the lever. I will be happy to make one and ship to you (gratis) if you find the need arises.
I think the root cause of my issue is that the piston bore was machined a bit too deep or the spring is a bit too short or both.
Thanks for those tips too, so far all is well after installing the re-build kit, was an after market one, and not HD...Drag Specialities..made in Japan!
