mountainrider2000
As I am in the middle of this same issue, what is the best way to remove the old O ring so as not to damage the housing, and to re install the new O ring? Any cool tricks to use on my 2000 Road King?
Did you just replace the 2 female connector lines, or did you go inside the tank too?
Yes from the bottom of the tank. You push on the sleeve and it disconnects with some pressure upwards on the hose.
You can order it here.
Search For A Part on Zanotti
