I own a 2001 Road King Classic and the return quick disconnect, (aft) started leaking. I disconnected the external line at the disconnect and removed the o-ring and discovered it was galled up on the inside. I also discovered that this o-ring matches up exactly with the tranny and crankcase o-rings. (Harley part # 11105) It takes plenty of patience to re-install the o-ring in the housing but it will eventually seat in it's groove. Before I reconnected the return line to the quick disconnect, I inspected the outer surface of the male part of the connector and found raised metal and scratches just in front of the groove. I lightly polished the scratches and removed the raised metal with a fine Scotch Bright pad and re-connected the line. No more leaks or seeps! My lesson learned is to use great care when disconnecting and reconnecting these fittings. Push the chrome ring up as far as possible so the retention ball bearings retract fully, then gently remove the fuel line fitting. I feel strongly that the retention ball bearings will raise the burrs I discovered if care is not exercised when removing and installing the fittings.
