ok, i am sure you guys are checking this every hour to see my update.... i had great success on the part i was working on. the clamps i purchased (4 just in case) worked perfect the first time, getting the plate back on just right might have been a little tricky than i thought at first... but with that fairly thick cork type gasket i am sure i got a great seal all around, i followed the instructions and did the key to on for 5 seconds then off for 10 then same again... i siphoned some gas back out of my riding mower for the bike, rode around the block and looked it over again... the stuff i worked on is not leaking... but my other quick connect is now... so, i guess i will be doing this all again, but now i know what i am doing... i suppose i messed with the connection enough times looking at it comparing it to the other that i jacked it up... i will turn it on again and make sure it is leaking .. i reseated it after i noticed it was leaking... but pulling the fuse, cranking a little to let the pressure off.. and it seemed a tad better after that... so, i will see if it clears itself up before i tear into it all again... but this forum has been a great help to me.. thanks to everyone.
jeff
hey everyone.... I am back in the saddle again... sweet!! last night i did the other fitting, when i got inside the tank i found that rear one does not connect to anything it is just clamped across the saddle part of the tank.. so, no extra clamping or anything, just got the old fitting off and put the new fitting up there in the tank, finger squeeze the clamp down on the hose as it lays across that high part of the tank and tighten it up.. put the tank all back together and no leaks... i will ride it a few days then change the oil and hopefully will be good for the this whole season... too bad it was raining this morning or i would have rode to work.
oh, and thanks to everyone for their help. it is greatly appreciated.
