free website stats program Fuel mileage | Page 11 | Harley Davidson Forums
Fuel mileage
'05 Electra Glide Classic.
SE AC, SE pipes
45 MPG in and between the small towns here in Eastern NC riding solo and keeping the RPMs at about 3.000.
07 Softail Standard. Stage 1, V&H Big R. 2 into 2, Screaming Eagle Heavy Breather. I am averaging 34.2 to 36 mile per gal. All riding is in town usually stop n go. Mostly only use 4 gears.
I got a 07 heritage softail 96ci no mods (YET) I do a mixture of highway back country roads and city. I average about 43 with my wife on back. haven't really had a chance to check it with just me on it.
I have a 91 Evo that I just replaced with a 93Evo. The 91 has a EV27 cam, adjustable push rods, CV 40 carb that was drilled out for bigger jets and K&N filter. Surprisingly, I got over 45 mpg with it consistenly. Mind you I ride solo with no fairing and at highway speed limits. I would like to rejet the carb back to stock setting but I think I'll need a new carb body for that.
I have an 02 wide glide and could get up to 51 mpg 2up when cruising at 55 in a group. At 75-80 freeway I got 43 give or take. I put on the v&h 2into 1 and the mileage stayed the same at the 55 cruise but went up to 46 on the freeway. Then I put in the 95" kit and 211 cams. I have been through about 6 tanks of gas riding freeway and cruise and have been getting right at 42.5. I did one mileage run at 55 and got 45.4. I can live with the loss of mileage in order to have the extra performance----jack
09 Road Glide with Stage 1 upgrade. Usually get mileage in the low to mid-40's. Usually ride alone and usually at a maximum of 70 mph.
Averaging 44 mpg on mixed backcountry , highway, a little in town. Depending on how much throttle I use. Ride alone. I'm adding Stage 1 SE Ventilator A/C, SE Fatshotz slipons & SE Pro Super Tuner this weekend , I'll Check it again to see the difference after the mods.:)
I have a 2000 FXR4 1340Evo stock with the exception of SE Stage 1 pipes installed when purchased new.40-43 mpg A little thirsty but not bad at all
1993 evo , V&H and I was told stage 1,. I just got 51 MPG on a trip from Kingman AZ to Vegas....not gonna complain average speed was about 60-65
09 superglide, 96"ci, 255 s.e. cams, vance hine short shots, zipper high flow air cleaner, P.C.III tunned at 13.8-1 , riding solo 90% of the time and gettin somewhere around 38mpg on the high way.
New and stock I was gettin close to 50mpg
