Be real careful with this technique. If the screwdriver tip goes further than you intended it can do some damage beyond the filter. You're also applying some torque on the mounting point where the filter goes on that it wasn't designed for when you rap on the screwdriver with the hammer. Not much but some. I'm sure the HD engineers designed it for the filter to be gently twisted on and off and nothing more.
Oh yeah - your method probably voids your warranty!![]()
trust me when I say it only takes a minimum of force to puncture the skin of the oil filter. If you use a long awl you can actually punch thru without hitting it with a hammer at all..just push and "pop"
That's a good observation Doc on the negative torque consequence possibly being applied onto the mount point. I can see where using a dull tip on the punch may not be the best regarding that concern.
Maybe my choice of "good whacks with the hammer" wasn't the best. You don't really need to lay down hard on it to get the hole punched. And agree, you don't want to keep punching to where you go 2 inches into the canister and hit the the threaded stand-off that the filter screws onto. Just the initial hole punched is all you need to get it draining -
Just asking here so correct me if I'm wrong ---- I thought the newer ( 08,09,10) came from the factory with Syn. already in them??
