J
Jack Klarich
Guest
The new sway bar links arrived today and I cant believe as to how easy they were to install. Even doing the adjustment. I didnt even need a wrench, till I had to tighten the locking nuts. I was told that adjustments are made to these to limit the amount of outside tilt the trike would have in a turn and also they can be adjusted to compensate for the crown in the road. Which can cause the trike to wander to the right of the roadway. This would also make riding one handed a lot easier.
My Trike Build
zoood
Think Anit Sieze on everything, You can now adjust rear camber on your trike this will be a big plus in the way it handles and tire wear, you can use a magnetic camber gauge from Harbour Freight Digital Angle Finder / Angle Gauge
