The sealing washers worked great! No more leaks in that area. However,... I had another. It looked to be the oil sending unit . Which I had to off-set with some brass elbows to fit on the Ultima 113. I resealed those connections and took it for a ride. While riding on a highway at about 85mph. I felt what I thought was a bee sting on the under side of my arm. Turns out. The oil leak fix I just did. That wasn't where it was leaking. The sting that I thought I felt was hot oil hitting my arm. Back in the shop. I was thinking it may be a high pressure leak. While the trike was on the lift. I started it up and kept it at a high idle. But I couldn't locate the source. While I had it on the lift. The engine was at ear level and I didn't care for the lifter noise I was hearing. I replaced all the lifters and the lifter blocks with "Jims" parts. While I was cleaning the push rod tubes and reinserting new rubber "O" rings. I noticed that under the center "O" ring ( there's 3 "O" rings per push rod tube), there's a flat washer. The washer was bent, not allowing the "O" ring to sit flush against it. I'm betting that this is what allowed oil to escape. The wind while moving is what sent the oil everywhere.
Click to see
My Trike Build
zoood
