Looks great and really quite ingenious. I am curious, did you close the open pipe spacer ends or have to use some RTV or adhesive to hold it in place while you were putting all the hardware in to keep it aligned?![]()
I left the ends of the pipe open, held it in place, and just used a 4" bolt with an acorn nut. I am going to be making the parts for my neigbor in a couple of weeks. I will photo the parts and give some details. Parts were all made with hand tools (hacksaw, drill, and file) and are not machined pieces, but they look good when installed. Thanks for your positive comments.
I spray painted everything gloss black. I may pick up some aluminum tubing and paint it instead of the galvanized pipe. I don't want to polish the aluminum because due to its location, etc. it would be very hard to keep polished.
After trying to find a 2" tank lift kit for my 2008 fxdc, I ended up making my own. Used some 1/8" x 3/4" flat aluminum stock, and a piece of galvanized pipe. Cut 2 pieces from the flat aluminum stock that were 2 3/4" long with holes drilled 2" apart. Cut the galvanized pipe to 3" long to use as a spacer between the gas tank mounting tabs. I needed to buy a bolt ( to go through the spacer and the tank mounting tabs) , 4 chrome washers and 2 chrome acorn nuts. I have about $11 invested. I owe firedyna thanks for giving me info about removing the tank, and encouragement. I was reluctant to tackle this mod because I's never been mechanical inclined. Here are a couple of pics.
.... .... .... get a longer cross over line mine is quite tight and dont want to be riding it when it rubs threw and fuel goes all over my hot motor. Thanks again Dave
Let me know how your longer line works out. I tried a longer line at first but the tank bibbs were so close to the frame that the hose still hit the corner of the frame turning the corner and then (with the longer line) it just bowed down closer to the rocker covers which I did not really feel to good about since they get quite hot sometimes. I ended up putting back on the OEM line. It doesn't really rub (since the tank and frame are bolted together) but it is against the frame.
