BUBBIE
Well-Known Member
I come from the OLD SCHOOL and yes to all the devices to help rid POPING on deceleration....
modified low back-pressure needs more fuel also on deceleration..... fuel injected vs: carburated ALL need same solve : to LEAN fuel condition.. pop..pop...
MANY OLD truck drivers remember PULLING out the choke on a gas-pot while using the engine to SLOW down....IF NOT you might blow the OLD worn-out muffler totally off the truck....
The primary chain ADJUSTMENT SHOE takes way TOO MUCH pressure against it if high RPM is used to slow bike down ie: pop pop pop
I believe in NOT using high RPM to decelerate my bikes... I ALWAYS shift if necessairy to a higher gear (when possible) upon decelerating. a lot of times I don't allow the throttle to back completely off.... NOT hard once you TAKE CONTROL of your bike. REMEMBER ::: YOU control it don't let it CONTROL you.
THIS will eliminate the small amount of poping you have AFTER you get the correct fuel needed to change the LEAN condition..
just my way,,, signed....BUBBIE
