DFHarley19
Wondering if my 2010 RKC bike will have similar problem? I just replace the belt and should have check that but I did not... Just over 17,300 miles... I hope it will be okay... :bigsmiley25:
Got the bike back together last night and rode to work this morning. The noise is completely gone and I believe quieter than when I first got it. Although I did buy used with 3000 miles on it. It always had a little HOWL if dropped into first gear coming up to a stop with the clutch in.
The bearing kit I got may have been a little more than parts sold separate but the bearing and race also came with the oil seal, retaining ring and a gasket for the forward part of the primary around the compensating sprocket.
Just curious, but why did you have to replace the belt at 17K miles??? I thought the belts could get 100K before needing replacement. Unless you got a little rock in there that created a hole.
So it seems your bearing was under the compensating sprocket and mine was under the clutch pack.
Just curious.. Do you happen to have the auto-adjusting primary chain tensioner ? Seems some are seeing premature clutch bearing failure because the primary chain is becoming too tight putting extra stress on the bearing.
