On my 09 FLHR, when installing a new comp (se comp). Glad I could Not get the Original comp for the 09...
When taking out the old comp and installing the totally New comp and rotor, I had two choices... Grind a little relief on primary case bottom to Install the new SE comp. OR pull the inner case loose/off...
I chose the take it apart. Seeing the Heated Race behind the clutch THEN looking at the dimpled bearing in the inner primary.... Sure Glad I Caught that. No sounds YET were there (or I could not hear them)...
SO. IF you DO replace the comp. , I'd go the FULL route and check that under 25$ race and bearing... and I chose to use a new gasket also$.
I have the stock primary chain adjuster and have never heard it too tight. When apart it looked to be normal (good) tension and the shoe looked great yet... Repair done at about 55,000 miles.
I use Redline MTL in the Primary and doubt it to be from that.
(change with engine oil change)
The Primary's do GET Hot.... Especially in Az. 100+ heat.
Added:
I use Less belt tension than HD says to use....OLD SCHOOL
